First of all, its great to see that there is a community like PWRA! I’m new here, but plan on getting involved in the community. I found it last night, and spent hours checking things out.
I am building small pressure washing setup to do fleet washing, but wouldn’t mind having the ability to do soft washing. I can buy a “barely used” honda gx390 motor for $400, so hopefully I can find a good belt driven pump to run with it and spend under $600 for the pump. I will start out with the setup in the back of my truck, a Chevy 2500, so no trailer. I need a bit of advice related to making sure the pump can be ran with the gx390 motor, how can I make sure the belt driven pump and motor are compatable? How to make sure that I buy the correct pulley sizes? Also, how can I know what unloader to get with the pump? Ive researched how to set the unloader, but cant find anything on how to make sure im getting the correct unloader for the pump. Is Udor the way to go?
Thanks for everything guys, I’m so grateful for any help!
