Shake the pepper over the screen when you finish typing. Anywhere you see a black speck, stick a period in. Good to go
My side is hurting Will have to tell my wife that one she is always giving me a hard time to!!
Read back through some of my rants. See what y’all mean. Wife says my rants are like trying to do a cross word puzzle lol. Might want to change the read time on this thread to double. Sorry everyone will try and do better…
Harold 14 ft trailer I am building. Going to try and finish when the frost hits. Winter project !!
Harold what Gpm is ur 12 volt ??
This is what u want when u decide and can afford to upgrade to air. A little over 600 bucks I think is what I paid.Had yamada it held up pretty good to can’t remember the price.
Got two of these don’t know how they will hold up yet. They are around 450 from northern I paid 350 a piece . Im using one as a dedicated transfer pump for straight sh and deisel to fill up the tractor. So can let u know before long.
5gpm kit from PT with the polybraid hose. I’m pretty sure its the bottom of the line, but its getting the job done. I’m ready to upgrade but the roof jobs are here and there. I think I should start marketing them more. I was thinking about getting some huge post cards printed with a lot of informative info and sweet before and afters to just place on select homes that look like they need and can afford it. I work in a lot of neighborhoods that roofs could use it but nobody even knows it can be done. When I do one they are all amazed like they never heard of it. My current five arounds and eddm has no mention of roof cleaning.
Please do. I think they will hold up great. There is not a lot of moving parts in these things to break. From my experience in the oil field you should be more worried about the compressor. If its a chem pump it should stand up good. I also did HAZMAT clean up at one point and we used the chem pumps or the petro pumps. They both stood up to heavy use if you use them for the right application. keep me updated. Thanks!
5 gpm will be fine don’t rush upgrading to air. If anything upgrade ur hose and put the widest hose reel u can fit so u can make long runs. An extra pump and use it to transfer with.Dont install a bladder on transfer pump and u will have one for backup.Make sure the one you spray with has a bladder on it if it dont it will help.
Using a variable pressure wand, turning down pressure will increase temperature.
Whyevenaddspaces
And then abbreviate:
Lolnpfwiwirofljkjk
That’s very nice and clean looking. I really like it. I’m going to plan on doing mine that way. However, I want to design a box hinged above the pump and accumulator to weather proof it.
@Harold
In case you’re interested:
https://shopwindowcleaningresource.com/suttner-st-54.html?pt=5b732c986ba6a
Definitely thanks
Thanks no box were it can get plenty of fresh air…
I’m referring to when it’s not in use
