I need a 3/8 inch male plug with 1/2 inch male threads. Anyone know where I can et one? I need to have a male leading plug on my reel that has a female 1/2 thread on the manifold. A reducer takes up too much room and the hose wont reel correctly. Any help appreicated
Northern tool has them on the shelf if you live near one but any PW supplier probably has them
Haven’t seen them, do you have a link?
No I don’t but if you call Pressure tek or pwp they can get one sent to you
I had the same issue the other day and went with the brass reducer bushing, only the small hex area protrudes from the manifold. It’s pretty much like screwing a 3/8" plug right into the manifold… # 2083 from the drop down menu.
Thanks
