Question…the bypass, I have it shooting sideways like before to minimize aeration but man does it blast hard at the opposite side of the tank. I’m open to ideas. Maybe put it down toward the bottom so it bypasses into water?
It’s a work in progress so hoses and wall attachment options are going to be fine tuned, especially that blue feed line. Waiting on some d-rings for the e-track.
if this your bypass? if so, just put an elbow there so the curve can cause a slight drag, BUT, mine goes thru the top and that doesn’t make any aeration as one would expect since bypass is when trigger is off anyway. so my bypass goes from unloader to elbow on top then shoots straight down into the water. it may or may not be your answer.
Yep, just a 3/4 barb of the unloader. I ran 3/8th hose for 20 years but this year my landa guy had been changing them out whenever one of my trucks go by there. It makes him happy so I figure it must be worth it.
