For those with experience with reclaim equipped surface cleaners, would you recommend Mosmatic, Sirocco, or Hydrotek surface cleaner with reclaim ports?
Looking to push 8 gpm, 2" vac hose, 100’-200’ vac hose length, likely the larger 425 CFM Gas powered Hydrotek vac pump. The wider the surface cleaner, the better.
Thanks in advance.
Any update on this: For those with experience with reclaim equipped surface cleaners, would you recommend Mosmatic, Sirocco, or Hydrotek surface cleaner with reclaim ports?
Looking to push 8-10 gpm, 2" vac hose, 100’-200’ vac hose length, with the larger Hydrotek vac pump. The wider the surface cleaner, the better.
Thanks in advance, fellas.
