So I’m going to be starting my business soon, all I have left is to get a small trailer and a higher PSI pressure washer (I currently only have a 1500 PSI hot water pressure washer) and I’m trying to find out what you guys would recommend as the minimum to start out with? I know most residential jobs are do-able with a 3200PSI/2.5GPM pressure washer from Amazon but I’m looking for something that will be reliable and not irritating to use (I’ve been told the cheaper washers would just bug me until I bought a bigger one).
Right now I’m looking at the Dewalt Honda GX390 4,200 PSI 4 GPM from Home Depot. It looks to be the best price for a pressure washer with those specs. I know the Honda engine is reliable but I’m not sure about the pump and other things that you guys would probably know more about. Is this washer good enough? Should I get something else? I’m going to be doing mainly soft washes and then driveways and sidewalks.
Any recommendations extremely appreciated!
