One of my customers called me and asked if I could remove this grease stain on her front steps. She believes it was from a melted candle. Any advise on how to remove it without hot water? Thanks for the help.
Heat it up with a $10 propane torch first and it will rinse rite off. I run into that crap all the time.
Thanks, good to know. Torch it and rinse with pressure?
Yep just heat it up enough that it started to liquify . Then use high pressure. Carful what direction your blasting it to . It will stick to whatever it hits. I can’t take credit for this my wife suggested I do it when she seen me trying to scrape it off with a screw driver . Apparently it’s was funny to watch because she was laughing at me.
That’s great! Thank you!!
