Trying to order up some new equipment for next season. We will stil be running a 2 man crew using an extended cargo so space isnt tight but not as large as a box truck. Im looking for a skid setup that has either (1) dual wand washer or (2) single wand washers. Havent found anything online like that. Anybody point me in the right direction?
One machine running two pumps is a diaster. One skid with two machines will take up a lot more space than two separate machines
ive been looking for a while now on how i should rearrange the truck. It can be hard to access at times. This is one of the only (2) wand machines i have seen available. Looked practical for saving space.
https://www.google.com/search?q=northstar+2+man+pressure+washer&source=lnms&tbm=shop&sa=X&ved=0ahUKEwjKkfOq66rYAhWuQd8KHR__CTIQ_AUICigB&biw=1421&bih=742#spd=7479462288778724301
Two separate machines. Custom rack made like @racer has on his trailer takes up the footprint of 1 machine. Get racks made for the truck bedrails and put two machines on one side and your reels on the other.
You won’t find a premade “space saving” skid.
Avoid Northern Tool like the plague.
3.5 gpm won’t clean much
so ive been told. was just pointing out that was the only 2 wand machine ive seen
Or stack the machines on top of each other
thought about that also. Was trying to see if i could find some type of stacking system for them as i dont have the resources to make one myself
Just draw what you need and go to a local fab or welding shop.
alright, well we are looking to pick up some new machine(s) also. Usually we use pressurewashersdirect.com but im open to recommendations on new places to buy.
where are you located?
Pressure washer direct is the harbor freight of washers
I would think you could take any washer, put a T on it coming out of pump and run 2 lines. Go by a Northern and see how they’ve got setup. I vaguely remember seeing one couple of years ago and wasn’t any big deal how they had setup. Sure Bob at Pressure Tec or Russ could tell you exactly what you needed.
There is very nice stacked unit with 2 pressure washers on PT state. In photo gallery page 13.
I think it was build by Bob, maybe gives you some ideas.
Those are nice. He built a double stack for Robert with Crystal wash. You could sit a coffee cup on top and it wouldn’t spill. Rubber isolators and exhaust out the bottom to a car muffler. Bob does nice stuff.
Where can someone get high end washers?
have considered this option. Found quite a few 10gpm machines even a few higher than that. We arent always running 2 guys, but when we do 10gpm split for 2 guys should be more than enough i would think
