Looking for a second machine?
2011 Envirospec Super Skid by Allison Iron Horse, Horizontal Adjustable Temp Burner (kero/diesel), Vanguard 18hp (unleaded), 5.2gpm, 3500 psi, custom upstream chem injector, custom source manifold, residential top fill with automatic cut-off, 3 inch bottom fill from hydrant, heavy duty 370 gal low profile water tank, custom aluminum cradle. Plus all my guns, hoses, etc. I spent $7k when building this rig in October 2011. I have all the receipts.
Must be able to pick it up in Scottdale, PA. Some assembly required.
Donald - I’m interested in the setup you described above, but just need to look into my budget a bit more. I’m located in York, PA about 2.5-3 hours from you. I’ll touch base with you in a week or two if you don’t sell it yet to discuss buying it.
