I was wanted to know the best way to clean limestone? Can I use my regular house wash mixture of SH, surfactant, and water? Will the SH damage the limestone?
Iām in the same situation here in Central Texas.
We have mucho limestone sided houses. My best luck, so far with the equipment I have, is DS a 2:1 (SH:H2O) with surfactant, on a pre-whetted surface, dwelling 10 minutes (keeping it wet), then rinsing it copiously.
Working on a budgeted 12 volt alternative to DS to get hotter mix.
You both need to research how to clean limestone on this forum. It will take less time than making this post and waiting for the answer
