Is anyone here familiar with or use just lauramine oxide as a surfactant? @florida_condo_cleani do you know if hang tite is strait lauramine oxide or if there’s anything else in it? After talking to a chemical company here in Canada, they’ve suggested it and say others they deal with use it.
Lauramine Oxide has many uses from cleaning to personal care products. It is a foam stabilizer, thickening agent and emulsifier. Amine Oxides produce very high levels of foam and are stable to high pH conditions and Hypochlorite bleach.
The stuff I used to use had no scent so scrapped using it.
Hang tite is laurimine oxcide they just put there own name on it. Almost all companies do that .
I’ve never seen the need to add anything else to the mix. One quart per 100 gallons is super soapy . For Housewash
Thanks guys
I use a surfactant called wetex down here. Works well.
Thanks for posting that, learned something new when I read about it on the nih site.
