any of you guys running kuri tek figured out a way to keep it from kinking? EVERY SINGLE TIME we do a roof we have to unroll all 200’ because its kinked at the very end. Anybody ever put something over it to keep it from kinking? a stiff spring maybe?
I haven’t used kuritec but any other hose like poly or garden I like to start from the reel with spa hose or similar. I got some really stiff 5/8 hose from Home Depot.
Retire the kuritech and buy the flextech rt hose. I have some that’s 7 or 8 years old still going strong.
When I was using kuritech it would develop a pin hole every were it would kink. I don’t think I got 6 months out of the kuritech
i will look into flextech! i literally JUST bought the kuri tek per suggestion from guys on this page… id like to get as long as i can out of it!
Lol you took the wrong suggestions.
i have 200 foot on a cox reel and I have never once had it kink!! Where is it kinking at? I love mine!
Flextech all the way. Also my dealer tells me to always unroll all the hose so I do.
right where it connects to the reel!
Take what you read here with a grain of salt and make your own choices.
You have a bunch of connections making it stick out of the drum center?
yep that would make since… i needed to run the galvanized 1/2" to 3/8" adapter to make it fit the reel
Add a 45 degree to the reel before you connect the hose
Use non collapsible hose 2 feet.then your hose
I want to say I installed another 45 on mine to make it not bend as much off the fitting. But I also think I am wrong and I don’t have this problem…Next time I spool it out ill see.
I keep 300 ft on the reels . I’ve never found it necessary to unwind it all endless it’s to reach 300ft
side note while i have some of you gentlemen on here. Im doing 2 large natural wood decks friday. Ill be cleaning them and have never used oxalic as brightener but she asked for them to be brightened. How do i go about it? Just spray the oxalic on and leave it?
I was even using mine this winter to spray liquid de-icer and I would pull 40-50 foot off. Its stiff as heck when its 3 degrees but never kinked!
