Hey everyone. I just posted to another thread so figured it would be a good time to drop in and introduce myself. I’m from Central IL, married, and have two kids. My regular job has long hours but only for a few months at a time throughout the year. I normally have late spring, summer, and early fall off. It just depends on the year and what jobs I want to work. I always stay busy doing something around the house so figured I’d try doing something on the side.
Last year I ended up with a Karcher hds 1200 be. It’s a 5 gpm and 3500 psi. It has a 16 hp Vanguard. It’s an older unit but I stripped it down to every last nut and bolt and restored it. I got a rebuild kit for the pump, new fuel pump for hot water system, belt, fuel lines, and replaced every o-ring on it. I also stripped down the engine, cleaned the crankcase, and checked it over. I wasn’t sure if I was going to keep it to use around the house or sell it. My regular job has long hours but only for a few months at a time throughout the year. I normally have late spring, summer, and early fall off. It just depends on the year and what jobs I want to work. I’ve been doing research over the past year but have really stepped it up over the last month. I stopped at a few other forums before I came here. I just landed here a few days ago but feel like I know a lot of you already. I have to say, some threads had me rolling but most have given some great information.
Anyways, I’m going to start with residential and mainly concentrate on house washing, gutters, and flat work. I do have to order a sc. I might put together a setup for roofs just in case. The subdivision we live in has around 600 houses and every single house has green on it. That was a big driving force in my decision to get started. I also have a buddy who is a farmer who said the local farm auction house is always looking for someone to do portable pressure washing. I’m not sure if that would be profitable but figure it could experience if anything and also open some doors with all of the farmers in the area. They seem to know everyone and could be good for word of mouth.
I think I might purchase a 14’ dual axle trailer to start my build. The one I’m looking at has pipe top rails and brakes on both axles. I know it’s personal preference but if anyone thinks I should go with another size I’m open to suggestions. I just don’t want to go too small and wish I would’ve went larger. We have a lot of cul de sacs around here but they’re big enough for even a large trailer to turn around in. I’ve looked at the different builds and trailers on here so have a pretty good idea on how I want to set it up. It will be a few weeks before I get the trailer because they just sold out on the 14’. They do have 16’ in stock for $50 more so that’s an option too.
I have wok coming up next month for my regular job so it will be a couple of months before I completely pull the trigger if I feel I’m ready. I figure that will give me time to get everything else in order. I do plan on an llc to protect personal assets, insurance, website, marketing, etc. I definitely don’t want to be some hack.
Thanks for all of the great info on here. I’m looking forward to hopefully being a participating member. Oh, and thanks for the laughs! I’m sure you know who you are!
