# Jrod advice
**URL:** <https://pressurewashingresource.com/community/t/jrod-advice/40424>\
**Category:** Newbie Questions\
**Created:** [August 25, 2025, 5:20am UTC](https://pressurewashingresource.com/community/t/jrod-advice/40424 "2025-08-25T05:20:18Z")\
**Posts on this page:** 1\
**Showing post:** 4
<div class="post-metadata">
**Author:** ![OhioFloMo](https://pressurewashingresource.com/community/user_avatar/pressurewashingresource.com/ohioflomo/32/44431_2.png) [@OhioFloMo](https://pressurewashingresource.com/community/u/OhioFloMo)\
**Post date:** [August 25, 2025, 8:56pm UTC](https://pressurewashingresource.com/community/t/jrod-advice/40424/4 "2025-08-25T20:56:38Z")
</div>
I’m just going off what you wrote in the threads you have made:
> [@SH draw question](https://pressurewashingresource.com/community/t/sh-draw-question/40290/1):
> I didnt try and find the answer to this before posting
> [@Ball valve setup](https://pressurewashingresource.com/community/t/ball-valve-setup/40409/2):
> ![file_00000000e374622f8abcd911a6d3caaf](https://pressurewashingresource.com/community/uploads/default/original/3X/a/a/aa3ce1ce9483c2e2efdf8a08a0f6b1ef38c0760e.jpeg)
> Chatgpt didnt generate the best image but yall get me
> [@Bran](#):
> Chatgpt says 0 degree #40
If you can’t find an answer to your question, it’s worth asking yourself why that might be. Nozzles and ball valves don’t serve the same purpose or perform the same way. A nozzle is designed to spray specific fan patterns at a set PSI, while a ball valve is nothing more than an on/off switch for water flow. I’ve never seen a nozzle that shuts water off, and I’ve never seen a ball valve that delivers a consistent spray pattern.
_[View the full topic](https://pressurewashingresource.com/community/t/jrod-advice/40424)._
