Hi, this is the back patio of my mom’s house, do you think it is worth cleaning it (I will have to pay for a rent pressure washer to do it)?? It seems that the concrete is very damaged and the result won’t be great (I just want transformation photos so I can go to another property and show them that I have done a prior job).
That should clean up. If you want to make sure that black comes off before renting a pressure washer pour some straight SH on, let dwell, and rinse with a garden hose. That will give you your answer before renting the pressure washer.
Thanks, I am not sure if I am going to be able to do it with a surface cleaner, as the only they rent in Spain is 50Cm wide in diameter and the PWasher I am gonna use is only 4GPM.
Thank you for the help, didnt know I could use that, only knew to post treat with Hypo that btw I will need to find here in Spain and do not know yet where is sold
