I’ve been doing some research in soft washing a house. Time and again I see the professionals recommend applying SH from the bottom up. I am not negating this - but my question is… Why is this the case? Why is this true?
I’ve pressure washed for a different industry and it’s always been more economical for me to rinse top to bottom, apply SH top to bottom, then rinse again top to bottom.
You apply it bottom to top because if you dont the run off from the top treats the bottom twice. The theory is that you get a more consistent application because of run down. I’m sure I’m not explaining it very well
So from your experience you’ve gotten good, consistent results with top to bottom? Awesome. I’m all about getting in and out as fast, yet as effective as possible.
Yes and I also don’t prewet anything but wood for cleaning and plants. It just dilutes your solution hitting the house. I guess I’m super hot days on the sunny side I will spray some water to cool down the windows
Never thought of that but it makes sense. I have also heard that the run off will cause streaks. Just like when you clean a wall before painting. From bottom to top.
We will have to agree to disagree on that one. It’s the same square footage one way or the other how does it waste time. Plus you dont have run down if you are using shooter tips. Not such a big deal if its vynil but anyother coating or material it matters especially if you dont pre wet. Do it the same way every time leaves less room for mistakes
I bet it’s the same concept. So hypothetically speaking if you did DS from top to bottom the tanker would streak or you will ruin the paint. Or scare or etch the aluminum
