Is there a cheaper way
I’m thinking about buying this for my buffer tank. Do I need this particular kit for $138 or can I spend less and do it with different pumbing? I’m on a budget and want to save money.
Thanks
You can usually save a little cash piecing it together yourself. Like with anything you pay more for convenience.
Just figure out what you need for your setup and look up prices. I like Sprayer Depot, pvc fittings online, or US Plastic when ordering fittings online. I usually order the hose, Hudson float valve, and filters from a pressure washing store.
Thanks
Tractor Supply has the Hudson valves.
