I don’t believe that’s where ur DS injector goes, most have a quick connect on each end and hook right into the end of the pump (between your machine and hose)
This was the built in barb i had removed to plug it
What engine do you have and how many gpm is the pump? It might just be worth completely upgrading the whole machine. Even if you keep the engine you can get new smaller pumps for less than $100.
Have you tried running it yet?
I would hope he has
If wanting to use current pump perhaps utilize a downstream injector with M22 connectors if such a thing can be had? You may have to plug the current hole with a bolt or plug, but perhaps not?
212 cc ohv gas engine and 2.8gpm
Im using this one cuz i dont have money for a new one and this was in my garage , i havent even got gas for it yet cause its been raining like crazy in miami. Got back to it yesterday cause i was in california for a bit and and noticed the bolt snapped in half when i tried to take it out so i was curious if its possible that all the parts inside are just as fragile as the barb i removed.
The last time this thing was ran had to be over a year ago and i wasnt around for it so i have no idea what was pushed through the pump.
If it doesnt rain monday i’m going to take it out and test it
She* lmao.
My bad, you dont see to many woman pressure washers on here.
Thats the beauty of it
Since you live where it doesn’t freezes it should be fine as long as it ran before. You might have to clean the carb though. I’d replace the barb, hook it up to water, and give it a try. If it doesn’t start we can walk you through cleaning a carb. It’s not difficult.
Thanks for the advice, see you in a few days👍
