Hi Andy here from Australia, can anyone advise me on intensifying bleach? Stronger and more efficient!!
Have a bit of a read from this forum and you will find the answer.
Nobody gives away such a heavily guarded secret that easily.
Add enriched uranium
Use stronger % SH than youâre using now
Using the stronests available in liquidâŚ
Why do you need it stronger, its pretty powerful stuff as it is?
The mould in australia is stronger. I am already adding some stuff to it, if you me it stronger you use less.
What type and %SH are you currently using.
Iâm in the Northern Territory and not having any issues needing stronger solutions in fact I dilute significantly so Iâm not wasting chemicals.
Also what âstuffâ are you adding?
Are you applying it straight, or down streaming?
Both mate, depending on the job.
What is the âstrongest availableâ? What percentage? Even straight 6% is way more than needed for any mold or algae you have.
