Hey Tim, with all due respect I strongly recommend you hire a professional. You could easily cause costly damage to your home. There’s a lot of factors at play and a lot of things that could go wrong if you don’t know exactly what you’re doing. Even if someone here were to give you a step by step guide of how to do it; the insurance and experience alone of a professional is worth paying for.
Don’t do that. Especially on the vinyl. By the time you spend the money on all that Olympia malarkey you’ll need and the time to figure out what you’re doing you’ll save a boatload of headache and probably not spend much more by hiring a professional.
And you’ll likely be sorely disappointed by the end result with the Olympia stuff.
That Olympic stuff is super expensive bleach diluted with water and then they add some proprietary junk that will leave a haze that looks like accelerated oxidation on vinyl if it’s anything like the behr junk.
He puts the deck cleaner in the tiny tank on the machine and nothing gets cleaned after paying $30 a bottle.
He sprays it on everything with a pump up, roof is blotchy and furry, vinyl is oxidized, and all the landscaping is dead because no one said to presoak AND rinse it off.
This starts out like the job i bid yesterday on a 1.6M dollar home, he wants to spruce up the 6500 sq ft paver driveway. " What do you mean that’s mold and not dirt? No, no one has tried cleaning it before." Hmmm, Sir are you sure no one has been in here with a small pressure washer trying clean this because the lines and blown out poly sand say otherwise? “Oh that, well i suppose I may have done that last year… " How much to clean it?” Sir, that will be 1493.00 and while I will change out the nozzles to protect the sand I can’t guarantee previously compromised sand will not be removed. “When can you start?” Just give them a few hours with the 2.3GPM Ryobi machine and you’ll sell it every time.
