Looks like Calcium deposit. Mist with water, Use F9 efflo and agitate. Then neutralize with f9 double eagle or another product with opposite ph, then surface clean.
You could try Oxalic or even step it up to muratic diluted 4:1 with water. That’s what they use to clean the mortar splatter off when they’re done laying them. You might have to agitate a little. I know I don’t have to tell you but do a test spot with the muriatic and see what strength works best. F9 Efflo is Hydrochloric acid. The only difference between hydrochloric acid and muriatic acid is purity.
