I am looking into getting into flat work / gum popping since my demand for it / hot water is rising.
Could someone recommenced a quality low profile preferably hot water box that would run at 4-8gpm. Price is not really an issue here, but please be reasonable considering I have to buy hoses.
As a side note, I am building out a stake truck and want to run 16gpm hot. Is it a good idea to simease them after the heaters? What is a good solution to this. I need to run a 48 or bigger inch surface cleaner.
After your last experience with Siamese kits I’d say you need to lay off. Would hate to see you come on here explaining how you blew half of your face off.
I am looking, but all I am seeing is 9.6 and maybe 10 around 3000psi. I really would love to push more water to stay competitive and maximize productivity. I have the ability to get some big projects and keep turning them down
I have no clue but I’m leaning towards no. Two 8gpm hot water machines will probably run you around $12-14k depending on brand and vendor. Then you need to connect them. That shouldn’t be crazy expensive but still an expense. Hoses, wands, reels that are rated for that flow and pressure are going to be pricey. I’d guess $15k easily.
Trying to send you a picture, but someone thought it be a good idea to put a BIG RED circle button to take you to the WW sight,over top of where you push the pic button.
Envirospec. Go into the largo section. Then find hot boxes. Up to 12 gpm. @anon29736956
