I am building a surface cleaning trailer rig (5 X10 3.5K axle) with 125 gallon buffer tank, 8gpm/3500psi (claimed) would a hot water kit “bolt on”? Do these pumps take hot water, I see the hose does. Is this just a bolt-on kit? I assume the surface cleaners will take the hot water. Is the water still hot @ 200 feet hose?
Hot boxes are add ons. Hot water doesn’t go thru the pump. Driveways are typically add ons for most people. I just don’t do them period. More easy money in washing siding I think.
?? How does the water get to the surface?
You hook up the heater After the pump, before the reel
