Hard recoil when pulling trigger
I have 4000psi 4gpm with buffer tank.2in coming out of buffer reduced to 1inch going into washer.When I pull the trigger I have a very hard recoil on wand.Is this normal.Do I have to adjust unloaded if it is a new machine.Bought it from pressure pro.Thanks for the help.
The recoil is normal .if you can’t handle it,get a k7 unloader. Unloader should be factory set…but I set it myself to be certain. Tons of research on here about it bubby
Momma always said I couldn’t handle the v8
