I thought you was buying a cab over or maybe that was a old post.
I am! But itās more for commercial plowing. I change my mind like I do my underwear. Daily and twice if itās hotā¦
I am really concentrating on snow right now though. The biggest plow company in the county is also a rental property manager. He has been forced by the banks to sell off houses to get caught up. Some are in foreclosure. They are very unstable and me being one of the only other big dogs in the area that plows stands to make tons of money if he goes under. I already have some of his large accounts like Walmart beating on my phone.
Hereās a good family truck for ya! 4 door even lol
Iām not a Chevy guy but I would buy this in a heartbeat and put an 11 ft plow and 600 gallon liquid de-icing rig on it tomorrow!
i was looking at a smaller truck like this, chevy colorado i think, my 2 cents is thisā¦ those are very light weight trucksā¦ you might not have much nowā¦ you thinkā¦ but it adds up with more gear come more weightā¦ more weight harder to stopā¦ you see where im going here? 9lbs a gallon i think is the weight so do the math and look for proper payload driveabilty. nothing worse than going down a hill and some jerk decides he wants to make a left and now you have to stop quicklyā¦ but cantā¦ now your riding shotgun in said jerks car. just some food for thought on those nice little trucks
if and when i can start making the big bucks, id like to get a 5th wheel type truck or a custom flatbed on a dually or hd 2500 truck and build a sweet rig on that.
Water Cannon has several 4/4ās with small price differences based on which pump you choose and they have free shipping.
Wow and i was worried i vouldnt fit it all in a short bed but here is proof
And Schertz has a large water tank under that deck. He must have an incredible shoehorn!
Like those lights
I have the pressure pro 4x4 with a cat pump. Just last week I used it after swapping to the 5.5 GP. So now its basically the 5.5x 2500. I did a full house wash plus all concrete that would normally take 2.5 hours in 2 flat. Basically a cookie cutter 2000sf house that I normally do. Only difference was the house was a corner house and had the side walk running down the side of the property too. Iād call that a huge difference. I have no issue cleaning that spot I missed with the SC with just a cracked open ball valve. I rinse flat work with a ball valve and did so with the 4 gpm pump too. So at this point id say the 5.5 x 2500 will do residential better than the 4x4
They make backing up at 30 mph a lot safer when Iām plowing big empty lots lol
I have only ever flicked them on 1 time going down the road for someone riding my tail with their brights onā¦
I built the skid so it clears by an inch through the back. No real need to take it out all summer though.
General pump is a little cheaper then cat. Their isnāt much difference between the two on the lower gpm machines.
Ya ill probably swap the pump out like you dis when these ones shot. I went with the 4gpm/4000 psi skid mount. Just because it might be a month or so before i get a buffer tank. Ive already poured all my money into truck, washer and 200ft of flexzilla. Im buying the pressure hose on my next paycheck and some elemonator.
Build your own machine. You will come out ahead.
Already thought of going that route but heck i already bought it
