Hammer head stock tip size
Can someone tell me what size tips come on the hammerhead 20" surface cleaner? I just bought one and there is no indication as to what they are. And I did a search on this site and I can’ t find this info.
More then likely, if the surface cleaner is new, it has 2502s. But, if that’s not stamped on the side of each nozzle there’s no telling what they are. The safe bet is to go ahead and replace them with the correct ones for your machine.
Thanks Micah. I looked for the stamp. I just don’t see it. My machine is 4200 psi @ 4 gpm. So should I put 2502’s on there? I turned the unloader down a quarter turn just to be on the safe side, because the rating is for up to 4000, though I have seen several sites that list the hammerhead as an accessory to that machine. I don’ t really want to lose any gpm. Are there 2.2 meg nozzles? Oh yeah I tried asking the saleman at northern tool all this and apparently I knew a lot more than him!
Funny quote right there!!!
I am sure you did!!!
Called general pump and got the part #. They are 2502’s . Hope this helps anyone else who buys that machine.
