If you nozzle it down u can easily reach eaves and gutter if required, I’m using a garden hose trigger spray atm because I’m mostly post treating and it wont throw up that high but has a good fan, my pump is 4gpm@60psi with 50m of 10mm.
My weed sprayer on my tractor has a tiny 1.6gpm and the 2mm 0deg jet goes 40ft so I’m sure with correct orifice sizing to your pump it will be awesome.
I got my pump from soft wash Australia for about $250, it is a 7gmp@60psi I run up to 60 meters of 12mm garden hose with a J-rod on the end, still going strong after 18 months. Easily shoots to the top of 2 stories as long as you don’t have a strong wind.
I resent the American public school system, and whoever decided that we shouldn’t convert to SI units years ago, for the fact that this thread boggles me…
