I only got a big one cuz it was 400 dollars cheaper than a good 150 gallon tank
Be super careful when taking a hard right turn. That unloader hose might have a ton of force on it not to mention if it rubs could be a nightmare for the tailgate.
O itās just hanging thereā¦I have to put it somewhere elseā¦along with the gas tank and 35 gallon tank so I can fit my sh drum
Damn I have 100gallon and only fill to 40 gallons but am also running 4gpm machine.
I figure if I need more I can unhook the Hudson so itās there if I need itā¦but I donāt really wana run with any water truthfully
Also Iām hoping to toss a shiny new 8 gpm machine on there early July. So Iāll be all set with minimum effort.
If you want some more space on the front I had every intention building a rack with back leg supports that set my skid up on the front rail as well as holding the gas tank and battery off to the right. Iāll find the sketch if youāre interested.
Basically two big beefing Lās with square tub and a brace across the back with a tray to the right for battery and bigger gas tank.
Sure if you run across it. I wouldnāt mind the machine being raised. Iām a little worried about that exhaust heating up. It was too cold here today to run anything and check out how bad my plumbing skills are. I have high hopes for tomorrow though.
Clean!
I predict youāre going to need a bigger trailer before summer is over, lol.
i remember this rig, is this a current pic? where do you keep your wands, surface cleaner and ladder?
that looks so clean and neat, what does the inside of the tool box look like?
Just go upā¦ I think I heard that in a video once.
This trailer is a year and a half old,itās done over 350 house washes.Wands,ladder,and surface cleaner are put in the bed of my truck.Im planning on having a flatbed or box truck in the next few months.I also have a skid I build for roof cleaning.It has 2 50 gal tanks,hose reel with 200 ft of 1/2 hose and 2 12 volt pumps.You just donāt need a 20-30 foot trailer with 25 valves to twist and turn to do what we do.I try to keep it simple as possible,that way thereās less to break or tear up.i will get you some pictures of inside the toolbox.We carry 1 gal of eliminator,1 gal f13,1 gal of onerestore,Extra guns,tips,extra unloader,extra Hudson valve,spark plugs,oil,chemical injectors,hand tools(wrenches and screw drivers),rags,gloves,and 2 of every fitting that is plumped on the machine and reels.
Thatās awesome, looks great
I try not to make mine look trashy but thereās so much stuff, hopefully itāll be more neat once i transfer everything to my van
This trailers got more leaks than the titanic! Only one that baffles meā¦ its seems my machine has a filter between the inlet and the actual threaded peice for the hose to connect. It seems very loose and wiggles aroundā¦is that commonā¦cuz its leaking a lotā¦solutions?
Pull it out and throw it away
pulled mine out replaced with regular rubber gasket and if ur using a plastic fitting like this u will have to tighten more than hand tight.
I just wanted to see someone else say it!!!
Lol. PS donāt put plastic fittings in your pump
