Forgot to winterized!
So here in Virginia is not uncommon to be 70s one day an snowing the next. Last night was 12 degrees an i pulled this out of the hose connected to my pump. I have only one filter connected to the pump its a brand new unit that i have only ran for 5 min total. Any reason why there is so much dirt passing my filter?
BermudaOne Pressure Washing & Restorations
Richmond, VA
804-617-1488
Did you check the strainer in the filter to see if there’s any holes or rips in it?
What is your pump connection made of? Looks like it could be rust from the connection that is settling.
Sent from my iPad using Tapatalk HD
Not sure… copper i guess. I doubt rust. I just purchased it 1 day ago.
Nick R.
Bermuda One Pressure Washing & Restorations
BermudaOnerestorations.com
804-617-1488
Richmond, Va
Strainer is good. I might just need to run it acwhile to clear the lines
Nick R.
804-617-1488
Richmond, Va
