Drop down a size on your rinse tips. Mine did the same thing when I changed to my 5.5 but I put my rinse nozzles that I was using with my 4gpm back in and it stopped pulling soap. Congrats on the new set up.
Thanks, I am hearing 10’s so going to pick some up tomorrow hopefully!
In other news, my LLC was approved late last week!
rinse with your soap tip. Put a 3 way valve on your DS injector with a line running to your buffer tank and another line running to your solution tank. shut off whichever you’re not using. A lot of the old timers around here say that if its enough pressure to stop the soap, is too much pressure for siding.
Drop your injector in a bucket of clean water when you’re done soaping and it will help clean pit your hoses.
