Had another thread from a few weeks ago, but that account was hosed up so bad that PWRA tech support could not get me in, so new thread here.
Finally have all the equipment on hand (surface cleaner coming later this summer) to put together the trailer. Still need to go buy some random bits like bolts, elbow, etc but the main pieces are here.
5.5 gpm belt drive unit for residential cold wash only… no roofs
***NOT driving with water… I am in a class 1 hitch situation, and limited to 1k in total trailer weight and 200lbs tongue weight - until I can get a truck. Until then, I want to keep weight down well under 1k. so not driving around with water, except for whatever won’t drain easily - maybe few gallons. So the tank in the direction I have it should not be an issue with the sloshing and tank design.
*** Not welding hose reels, so that I can upgrade easily to a bigger trailer as soon as funds permit (after the truck purchase), so will be bolting them to wood initially.
***Also keeping the protective bar on front of PW. Might remove the handle, but may need to use this trailer on rare occasion to get the rider mower to repair shop, so wheels are not coming off until I get my bigger trailer. Will bolt it down to floor.
I am going to get a board a little taller than the PW to put along the front of the trailer in front of the pressure washer to protect it from damage while driving. I will secure the board to the trailer with some type of a latch so I can easily slip it off when I get to the job so the PW can vent into air and not the board. Will probably use a latch hasp like this one:
The filter is now going between the tank and the PW (thank you IBS), so the supply line from the reel will just be the 1" crushproof (it is being represented by a piece of square foam in this picture). Is the 1" too big to use? Want to use the crushproof so I can lay my surface cleaner on the floor in front of the tank and PW and not have to worry about it restricting flow.
I am running supply through the reel to start with, and see how it goes. Some say it will restrict my flow too much, some say it won’t… will fiddle with testing it down the road sometime. The other part of the Y splitter will be a short garden hose for bucket filling, clean up etc.
I will have a drain coming out the back of the tank and will have more 1" crushproof with garden hose nozzle as the drain… not that rigid pvc.
I was told I need 20" of crushproof between the filter and the PW… so I will put the filter there between the two, after a small shut off valve to allow cleaning the filter easily even if I have water in the tank. Anyone have a good, small shut off valve they like? The one I have is kind of giant…
Will be putting an elbow inside the tank to direct bypass to end of tank opposite the PW feed line. Hudson valve is going into the tank lid.
Not sure where to mount the downstream injector…at the hose reel maybe… not 1005 of pros and cons on that yet but want to minimize connections and such to just what is needed.
I think I am safe on weight distribution with the stacking reels over the axle. Do they need to come father forward? Wanting to be able to use that fender to help with mounting.
Thinking my box of chemicals (currently single gallon bottles of SH - only working 2 days a week this summer) will go in the front corner, adding some tongue weight but not a ton.
Spare tire, extra 50’ of PW hose and supply hose rides in the trunk.
Will probably add a small vice to the front and mount a plastic tool box for a few immediate need items like safety glasses, o-rings, gloves, small first aid, etc.
any feedback/guidance appreciated.
