To see what nozzle is clogged flip over the surface cleaner use your foot to stop the bar from spinning and pull the trigger. It will be obvious which one has debris in it.
Thanks I will check it out in the morning
Yah man what ever works
I gotta send you some wd40 lol
Also I’m running a 24 inch aqua pro with a 5.5gpm at 3500 psi what is the proper nozzles for my surface cleaner
What did your research using the nozzle chart tell you?
I looked at the nozzle chart my cleaner is a two nozzle so I’m think if my machine is That should be 2.25 gpm on each nozzleSo I’m thinking my tips should be 2.5 tips am I reading chart properly
