Enough Juice?
6gpm belt driven hot water machine.
Enough juice to sufficiently run the Big Guy to its full potential?
Im going to use the Classic for my 4gpm cold water, but need the extra boost for bigger jobs.
Thoughts?
Thanks
Kevin
The big guy would do fine with that flow on light duty maintenance concrete washing.
If you are actually trying to clean dirty concrete, hook the classic up and move full speed ahead.
Thanks for the response Tim. Yeah that’s what I was thinking also. Its nice to have the extra 9 inch cleaning radius on the bigger jobs. I just wanted to make sure it would push out enough flow to clean properly before I pull out the funds.
Thanks
Kevin
