Hello guys quick question I want to use an elevtric pressure washer for bin cleaning. I do not need a hugh psi amd also would prefer the quietness of an electric pressure washer. I want to know where i could hook up power besides customers house?
Y’all, if you answer you’re just an enabler.
Most cars that are built after 2003 have a plug just next to the canooter valve up by the Cadillac Converter
Purchase a Ford Lightning F150 or something similar and you’ll have plenty of outlets to pull from.
sounds like the neighbor’s house fits the bill perfectly…
Get a generator to run it or a battery backup unit like they use on computers. They have some really good ones now for servers.
For ease of use and reliability, what most of us do in the industry is fasten wind turbines to the roof of the truck, then Hook Up a dozen oscillating fans to help supply the wind to the wind turbines. The fans are usually powered by solar panels. The solar panels Will need to be lighted with lamps using incandescent fluorescent bulbs to supplement the Sunlight. Those lamps can be powered with a bicycle where you turn the pedals to produce electricity. The bike needs to be secured to a strong stable surface so what a lot of guys do is use something like a generator as a solid base to secure the bike frame to. That’s the compact version but i guess a Power inverter could do.
