Downstreaming. Pressure or gpm matter most for throwing water high. i.e. 3500psi 4gpm or 4000psi 4gpm. Searched it. Didn’t see. Thanks.
Will use GP high flow injector and jrod if it matters.
GPM is ‘king’ when it comes to reaching higher peaks, night and day difference.
And welcome to the forum.
Neither. Gravity is king. Find a way to overcome that and you’ll be on to something.
Thanks. Been learning a lot here.
I chuckled a bit at that one.
You don’t need anywhere near that kind of pressure for distance. GPM is what matters. 100psi is capable of shooting 35’ vertically. I
Actually, it’s the law!
