That’s not anything you did. Is there a tree in the area that drops acorns or anything? What % did you pre and post treat with? The tire marks towards the top will need a degreaser. Hot water helps.
Thank goodness. It’s a wash I did for a neighbor. There is a large live oak that hangs over part of the drive. My pre is a 2 gallons 10% SH to 3 gallons of H20 and 5oz. Elemonator. My post is straight 10% DS.
Those are brand new tire marks from the homeowner driving up and running over my hose mid-wash.
Those black streaks are likely acorns that are getting ran over by the car. Get a pump up and spray like 4%-6% on those black streaks. Don’t let it dry and keep reapplying if need be. One heavy spray ought to do it though. A 12v would be quicker and easier.
@tcmitchvol definitely use a higher percentage bleach 4-6% and itll disappear ,downstreaming 10% still really only gets you to ~1% and most here will post treat with ~4% everytime
Had a driveway a long while back that had these all over. After surface cleaning, a hot mix of SH sprayed directly on took it right off. Pretty much just disappeared.
AA- This down streaming % issue has been one I’ve been trying to solve. I have a 7:1 injector and use 12% SH on my 4gpm machine. Is there any way possible to DS and get 2 or 3%? I have an Xjet but find the DS much easier. Thx
For the driveway I’d just use the x-jet its not worth you time to go and try the other stuff unless your constantly doing stucco houses or something. For a drive most of the time you can carry a bucket to one spot and spray the whole thing. If you really want 2-3% from ds you can use a small 12v pump to force feed the injector, there is already some threads about that
No. Don’t believe all the hype and gimmicks. A number of guys on here have tried the various injectors promising incredibly high draw rates. It’s all snake oil.
I think @squidskc found something a while back that he liked. Not sure if he’s go any updates on the injector as it’s be a a couple of year (give or take).
