After searching on here, I still haven’t found much information on downstreaming using the M5 Xjet instead of a jrod. I’ve been doing it this way on several projects and it seems to do a better job.
Does it throw a hotter mix in a downstreaming capacity?
I simply switched out the jrod and put on the M5 xjet on the end of the gun and it drew very well. I’ve only got a 4gpm machine, so maybe that’s why it worked.
