Curious on the house was mix if I’m using x jet what would be a good mix an what Chem to use for it thanks
Sent from my SM-N910R4 using Pressure Washing Resource mobile app
If you are not running a straight mix, you might as well use a regular injector. I use straight sh and 2.5 oz’s elemonator with no proportioner. T me it doesn’t make sense to use an xjet, if you are running a mix you could get with a regular injector. It is too much of a hassle, filling and moving around pail. Although I have a dedicated 50 foot pressure hose mated with the chem hose with cable ties.
2 gallons SH, 3 gallons water, 5ounces of your favorite soap.
Sent from my iPad using Tapatalk HD
It would depend on if you are using a proportioner.
Sent from my SAMSUNG-SM-G870A using Pressure Washing Resource mobile app
