I removed my short bypass hose and running about 6 feet to a buffer tank instead. The short hose is 3/8" but in 6 feet is it better to go to a 1/2" with a 5gpm at 4000psi machine?
Plus i cant seem to find how to change where it says in my profile from 4gpm to 5.
Pretty sure you can’t change it. It’s an accolade to show your status. Apparantly I’m still a new member…ive been on here for at least two years.
Is it possible i could have an unloader that has an extra connection for the longer hose and then leave the short one hooked up also? There is a bottom bolt and a allen screw on the oposite side of my unloader. After every use i squeeze antifreeze through inlet but now it doesnt come out of the top outlet since i installed the hose to tank.I sometimes turn the pump over but this time it was taking a lot of antifreeze. So just sqeezing that in,was it even getting to the pumps valves or just going through the short hose?
So, recently someone told me I had no tact. Maybe not. You’ve been on this forum for 4 years, have two hours of read time and asked an unintelligible question about a basic part of a pump that should have been known before your ever started the machine the first time. I think it would behoove you to find your own answer and no one else, including myself, waste their time on this post. .
