I have a 120V burner that was powered by a belt driven generator. A while back the generator went out. We have been stretching an extension cord most everywhere we work. I have another burner in the same truck that is 12V. No problems with it. I am needing to fix the 120V burner but unsure which direction I want to go. I have considered another belt driven generator which would run about $500. I have thought about changing the burner over to a 12V which would run about $800. Or I have thought about buying a gas powered generator that I could also use for other things. Of course with this option I would also be burning gas while using my diesel powered burner. Any recommendations? Thanks.
Replace the generator & be done with it…it’s only $500… Not $5,000. Switching to 12v makes no sense, extra generator takes up space and something else that could break down…just saying
The fewer pieces of machinery that can potentially break the better.
Thanks Guy & Thad. After I posted this last night and reread it, I pretty well knew what I needed to do. Guess I just needed to see my options laid out in front of me.
