Add a short extension between the bulkhead fitting and the Hudson
Thanks. I picked up one at home depot today I’ll try it Saturday
Finally finished, except for ordering a remote controlled soap switch from @SchertzServicesLLC. Would I have to have 2? One for each reel?
Why does it look like your hoses are rolled up backwards? What’s the generator for?
Looks good. I see bare floor space, wonder how long that will last LOL.
Looks great Kenny! I bet you’re anxious to put it to work!
I wouldn’t think you would need two remote switches as long as both reels are being fed from the same mix tank. Couldn’t you just use a 3 way valve and select which reel you want to feed depending on which hose you plan on using at the time?
No I have them looped over into quick connects. The generator runs the recovery vac
That might work
I would think 1 box would run 2 injectors. But it would probably mess up mic ratios. I wouldn’t recommend it. Plus both would have to be soaping and rinsing at the same time.
Listen at you upselling me for two boxes lol
You could try it! I don’t make much money making them. It’s just fun for me and I like helping guys out.
It’s a hobby at this point lol
I’m sure. I was just messing with you
