Need some help here. I’m at a job and the tank is barely getting water. They have a well but pressure is good. Never had this happen before.
Unhook your water supply line and drop it directly into the tank if you have it plumbed through a reel. Could be something blocking the water flow internally. A problem with the float valve for instance.
Thanks!
Hope it helps.
Yes, thanks! I was so frustrated, I didn’t even think about disconnecting the hose…felt stupid! Lol I’ll figure out the issue next.
Lol, I have those moments frequently
Whoa. Must have been a long night last night lol.
