Just got called to bid on a project. Nothing I haven’t done before just on a larger scale and a bit higher up. Looking to get opinions on if you would use a boom lift to get the top of these brick areas/cement or just bleach it out with a high concentration mix. Yes I’m insured.
Im thinking you MIGHT get it but the time you spend with a shooter tip trying will eat you up. Maybe with a long extension you can stay on the ground, but Id try for the lift if possible
Well turns out I’ll be able to get an atrium lift in through the courtyard. But if your plan would be to use a shooter tip to high pressure wash concrete that’s 30 feet above your head then yeah, you definitely shouldn’t bid the job.
