Quoting the largest residential job ive had yet. Just curious what kind of ballpark price you guys would be at for 7,000 sq ft residential flat work. A landscape guy is subbing this out to me, They want it power washed and sealed. Im seeing quite a bit of moss growing up in the cracks in some areas as well. Any info is much appreciated.
Clean it then treat it with ortho complete vegetation killer . Not round up . Wait several days before sanding and sealing. I would be between $5-$7 thousand
Depends on whether it needs re-sanding and what type of sealer. If it does then close to $1 per sq ft for everything. Any decent sealer you’re going to have about $.25 per foot in just that alone for materials.
I honestly don’t know what’s in it. I use it because it the only thing I’ve found that works.
We have to warranty our work and round up let me down a few times. Ended up resanding and sealing a few decks .
Yeah I did a driveway earlier this year. It was a wash, re-sand (polymeric), and then seal. It was a couple thousand sq ft. This one is much much larger, but I also don’t think this one is going to need much of a re-sanding. And it wouldn’t be polymeric sand for this one, just a regular type of filler sand, if i’m not mistaken. I’ve only done that one driveway before so I still have a lot to learn regarding sanding
