I started with 2.8 gpm Simpson, I have stepped up to 4 3500 Unit and yes I agree this is where I should have started. But I started where I could and have built up, it is what it is. My next upgrade will be 8 gpm. But anyway. I broke down and got a ball valve and I was impressed. I can get 3000 psi or 1000 psi very easily, yes I did use a gauge.
Nicely done. That 4 gpm 3500 will be a good workhorse for you. Can do pretty much everything with it. Just going to be a little slower doing concrete and rinsing. Get you a M5DS nozzle the appropriate size and you’ll be rockin.
I just ordered a m5ds and m5xjet. Too bad they won’t be here by Wednesday morning. I ha e a big church parking lot to clean. I will just pre treat with pump up sprayer Lol.
Yes it’s at the end of my whip line just before hose reel
Racer
February 19 |
Do you have a ds injector?
Visit Topic or reply to this email to respond.
In Reply To
Clean_Start
February 19 |
Then just use your ball valve to pretreat, can’t turn the pressure up much with it or ds won’t work. What I use 95% of the time. Just open it all the way up and then shut it off enough where it’s shooting about 7-8’. Long as it’s pulling soap you’re golden.
