Any ideas to remove this
It’s a brown window frames.
From picture, looks like might be aluminum.I would mist some one restore on a small
test area, dwell couple minutes , rinse off and see if any change.Keep us posted.:smiley:
Bill Sullivan
Bill’s window Cleaning.
902-471-8008.
Thanks
Hey bill, it worked somewhat i will need to try something else not sure what about winsol aluma wash???
Is that an aluminum window frame? I had a similar issue after a wood siding job we stripped. We used Miguires tire shine that worked amazing and brought it back to black. The customer had tried this previously after the other contractor was fired off the job.
Britton Emerson
Emerson Exteriors
hey britton its a aluminum frame (brown) thats oxized
One restore is a fantastic product, but I have run into situations with glass starting to
etch, they were too far gone even for one restore to work. I would go with Britton’s
suggestion and see how that works out. Keep us posted, Good Luck!:slight_smile:
Bill Sullivan
Bill’s Window Cleaning.
902-471-8008.
For a $8 investment it’s worth the test spot.
Britton Emerson
Emerson Exteriors
