^this, the 2 combine to produce chlorine gas, something no one wants.
What size machine you running now?
I think hes running 2 4gpm machines and only cuts both on when rinsing and surface cleaning.
As a new member you don’t know about my sordid past. I used to create CHLORINE GAS using sulphuric acid and table salt to turn the base of a certain illicit substance into it’s salt. If I create little chlorine gas using muriatic acid, no one will be hurt I can assure you.
No stop the whole house will EXPLODE🤯lol
Grizz is right: I’m still cowboying two machines to create the MONSTER when I need it, but mostly use only one for everything not related to surface cleaning.
