Always use a filter befroe the pump
Here is a picture of poly shvings from our tank stuck in the check valves of the 8 gpm pump. We got in a hurry to get a machine on a truck and running.
Thanks for sharing that hard lesson learned with us.
Thanks for the reminder. Mine still sitting in the box it came in.
You guys have a filter to recommend? Is this something to just get at pressure tek?
This one from PT works well.
1" FTP In & Out Clear Bowl Water Filter - Low Pressure Filters
Thanks
Tim how are you i was wondering if you think this will be good for me my washer is a 4200 psi 4 gpm
I need a filter and was wondering about ball valve here is a link
Shopping Cart
The link is empty. What is the part number?
iPhone - Tapatalk
1" FTP In & Out Clear Bowl Water FilterCode: 4455-1
Brass Hose Swivel 3500 PSI 200 Degree 3/8" MPT x 3/8" FTPCode: 3491
3/8" FPT Heavy Duty Ball ValveCode: 6292
http://m.pressuretek.com/hedubava.html
Yes on your selections.
iPhone - Tapatalk
