The 3/8 is around $400 it will last a long time but needs rebuilds to often. There cheep to rebuild. It’s just annoying. I would just get a 12volt system. Make some money then upgrade later or when it becomes necessary
how many gpm would the flojet produce w/ 14 cfm compressor 200ft of hose using 0040 and 2540 tips
Thank you!
also what size would your hose be with a 3/8 pump? inlet and outlet?
I don’t know I’ve never used one.
I use 5/8 hose if I need 300ft. 1/2 is fine up to 200ft. If your reel is big enough 18” I would definitely use 5/8 it makes a noticeable difference.
I agree it’s a risk. I feel like after talking to dot I picked the least dangerous of two bag choices. I’ve been pulled over twice by dot . Once for a tail light and once for not wearing a seatbelt. Both times I left with at least a dozen citations and only 15days to correct them. All minor stuff. I do tend to stick to back roads in the morning when the tanks full. Luckily I’m usually back to legal by lunch time.
Pretty sure they go off the size of the tank not just what’s in it. I know they still count sh mixed with water still sh.
Your correct it’s based on the size of the tank if they really want to bust your balls. Just a FYI most states have a legal limit of 1000lbs of coustic material to stay under hazmat. But the federal law is only 43 gallons
Can I get the same if not better results from a 1” trash pump?
Are you talking about a gas powered trash pump?
Yes I am
It would last about a day then be destroyed by the chem. Also 3-7 gpm is all you need for roof cleaning. Trash pump at 50-250 gpm
His name is water boozaka lol
