I still don’t see the purpose of softwashing a house with a 12v or booster pump and then dragging another hose behind it from a PW to rinse. Seems like twice the work. Downstreaming is cake. I’m only on my second chem injector in 2 years and they’re cheap. Yeah you can get a stronger mix with true softwashing but I’ve washed some pretty green houses with a 1% mix and it’s all good. This was done two days ago at 49 degrees and 1% mix. Applied soap once to this north side and 5 min later most of it was gone. Applied a quick second coat and gone. Even mildew on brick has come clean with 1% for me
Soft washing with dedicated pumps is a benefit for vendors, not contractors
As professionals we should use the proper tools with proper techniques. I totally agree unless there is a specific need use the PWer to softwash the house. Use the red tip or more pressure than needed? Absolutely not.
